Chrysler ignition switch
Davidsjr
I have a 1972 chrysler 85hp engine. The model number is 857hd serial number 2612. My ignition switch went out and i dnt know wat the correct one to buy is. The one that jst went bad dnt have any numbers on it. All i kno is it has 6 terminals and is push to choke. Any help
Silvertip
I take it you are just shotgunning this "no spark" issue and not doing any real troubleshooting. You have already bought a CDI box and new spark plugs and are now looking for an ignition switch . To prove the ignition switch is bad simply disconnect the two MAGNETO wires. With those two wires disconnected there should be spark. If not, you have a different problem. Troubleshoot the issue -- don't just keep buying new parts. Bad wiring may be the problem. What happened just before the no spark situation happened. We cannot help much without details.
