cturboaddict
- Aug 29, 2010
- 224
Okay, as time is getting nearer for better weather- Im looking at picking up a few more items to start my rewire. Id like a few suggestions on what sizes of a few items, as I dont want to start a fire.
Here are the load items~
1. CMC PT130 tilt/trim (operates on two 40amp relays)
2. Ignition
3. Bilge
4. Horn
5. Radio (nothing fancy, just a radio and some speakers at the moment)
6. Dash Lights/Running Lights
7. Anchor Lights
8. Gauges
9. Interior Lighting
10. Cigarette Lighter (for charging cellphones and what not)
Im looking at running a dual battery setup, with a Battery Selector switch.
Im probably looking at 4gauge wire for the batterys to the selector (also where the tilt/trim will plug in, and then 6or8 ga from there to the fuse panel. 14 ga after that.
Question is- What size breaker should i use after the selector switch towards the fuel panel? Or do I need two? (one for each battery? If so, What size? Also, Im going to run a resetable breaker inline for the 2 40amp relays, is 50amp safe there?
What is the best place to tap into a switchable source for the gauges? (Its a 76 Mercury 115 TOP)
Anything missing here that Ive got jotted down? Help me make sure Im on the right track.....
2. Ignition
3. Bilge
4. Horn
7. Anchor Lights
8. Gauges
