boatingneophyte
- Mar 16, 2010
- 2
We're thinking about buying a used Polar 256 CC.
The rub rail (molding) covering the seam between the deck and hull is pulled away from the fiberglass for a short stretch near the stern. The rub rail and molding screw is pulled out about 1.5 inches at its furthest from the deck/hull.
The rub rail is NOT broken. It looks a bit like a strap hold, if that makes any sense.
The problem seems to be confined to about 8 - 10 inches of rub rail. It is located on the port side near the stern, where the deck curves into the transom structure.
I can see the seam between the deck and hull where the rub rail has been pulled up. No sign of sealant.
Otherwise the hull and boat looks in good shape.
Does this suggest stress/abuse to the hull? Can it be repaired?
Or should I run as fast as I can?
I really appreciate any advice, as the log-in name says it all. Thanks.
