Draining exaust elbows
bspeth
One elbow had about a half of a pint and the other one only about 2 ounces.Where the boat is parked for hibernation is a slight bit higher on the side that produced very little water so I assume this is normal.However I thought it best to ask someone who is not assuming and actually knows.-Blair
alldodge
Re: Draining exaust elbows
If it's only a slight bit higher I don't see an issue. So long as the engine was mostly level when winterizing. If you want to make real sure, put a level on the swim platform and if it is slight and not an optical illusion you should be fine
