Re: Dumb(gasket) question?
Sounds like you have it covered !! Make sure as soon as you tighten them down to check and see if you have all your modes(fwd,rev neut.).I am a real worry wart when it comes to putting the drive on.It is a relatively simple task ,but so many things can go wrong.Ujoint catching on the large Oring and moving it out of place,shift cable turning out of groove,shift arm not lining up under belhousing,accidentally moving prop and taking drive out of fwd w/o realizing until drive is on.You will pick up many little tricks of the trade here that will help assure you that none of this crap happens.Like glueing the large Oring in place,duct taping the prop from moving etc......Charlie
