engine problem
atrinque
I have a 1997 Yamaha 200hp. The engine starts & idles perfect. However when you throttle up it bogs down and wont take the gas...it has done this intermittantly, but is getting worse now. The spark plugs only have a few hours on them. Someone suggested the coils might be going bad. All suggestions would be appreciated !
Ray Neudecker
Re: engine problem
It has all of the signs of a fuel restriction. Is it a carb motor?
atrinque
Re: engine problem
Yes it is a carb motor.All carbs were rebuilt with less than 50 hours on them.
rodbolt
Re: engine problem
check the fuel pumps and drain the carbs. if you have any trash in the fuel system the time since last overhaul is irrelevent.<br /> good luck and keep posting.<br /> also test the ign system for proper spark.
