Josephmast94
- Nov 14, 2013
- 12
I have twin Yamaha 04 F150s, the port side just started acting up (shaking and not preforming like the other engine). after a long series of test we determined cylinder 4 is not firing. replaced the spark plug, even though it seemed to be sparking just fine, didn't help, and compressions are all around 150. I switched two of the injectors and used a test light, there seems to be a pulsing ground going to the injector, just like the others. I even bought a YDS kit to run the codes, but it did not show any error codes or any problems. like I said there are problems, when the motor is running you can unhook the # 4 plug wire and it runs the exact same, no change in tone or RPM. when we tried that on the other motor it started running rough just like the port side does. so I am very confident there is a problem somewhere, just need help figuring it out. I will be online checking for updates tonight so I will be able to respond rather quickly to any questions. thanks in advance for any help.
