Force 120 Fuel Pump
dmegan
1998 Force 120, Running at good speed today, when I slowed down the boat cut off and wouldn't restart. Carbs recently rebuilt, though I did have a stuck float that I had to fix. I'm thinking the fuel pump might be shot. It also start to stall a little if you gun it from neutral, needs more of a steady climb if that is useful. ANy thoughts? I would try to restart and every once in a while it would fire for a few seconds then die again.
jerryjerry05
Welcome,
Start with a compression, spark test.
Does the ball pump up and stay firm?
Test the overheat system and see if that's why it stalled.
Check the hoses and connections.
