force 120 Spun hub?
i have a force 120 ..when i was pulling a skier yesterday the motor reved up but the boat would not move...motor sounds fine and revs up fine with throttle but the boat will not go anywhere...is there possibly a shear pin in there somewhere or is it the prop or what..the prop looks ok on the outside...please help
roscoe
Re: force 120 Spun hub?
Does the boat move at low engine speeds? Then just seems to slip when the engine revs up? Then it is a spun prop hub that has worn out. You can have it fixed for about $40. It is a good reason to have a spare.
