Justtlsnew
- Jul 8, 2018
- 18
Greetings and thanks for reading my post. Ive owned a few boats but have not done a lot of service to outboards. Got this boat about a week ago, got it running but was backfiring. Tried new plugs and seafoam, eventually found out the top 2 of the 4 cylinders were not getting any spark. When I pull the wire of 1 or 2 no change in the way in runs. I found lots of info here and have tried swapping out coil packs with the bottom cylinder but the problem stayed the same so it would seem the coil pack is fine. I was about to try swapping the blu/yellow wire from the stator to the CDI but it appears that the onlu one of the CDI modules has the blu/yellow. The older looking CDI appears to have a off white looking wire in the same position, Im confused. Should I swap the blu/yello stripe wire on the block with the off wht wire on the block? What is the best way to isolate the CDI module. Keep in mind im ok with a wrench but electronics not my core strength and I don't have anything for testing other than a light that shows power no power. Thank you for any info. My best to you and yours....
