Ford 302 engine coupler
Jakem
I'm wondering if these are able to be tested. Mine looks almost new however I don't want to pull my engine out again if I don't have to.
Ayuh,..... The only test, is a visual inspection,.....
achris
More fish than mountain goat
Apart from visual, about the only test you could do if you really wanted to do a mechanical test would be to rig up a some form of torque test jig. Get an old input shaft and weld a bar to it at 90 degrees. Set the coupler up in a vice or holding frame and use the input shaft to apply a load. Much the same as propeller hubs are tested.
Chris...
