Hello guys, need some expert opinion on the install of a fuel flow sensor on my VP 5.7GS. The unit I will be installing is a Garmin GFS 10 to be linked to my Garmin 740s. My dilemma is this: The garmin fuel flow meter requires a pre filter before the sensor to keep the paddle from being clogged. My engine has a factory spin on fuel filter mounted on the engine, then electric fuel pump then USCG lines with screw on fittings to the carb. The fuel flow sensor has barb fittings for rubber line and can not be feasibly or safely put behind the engine mounted filter and fuel pump. The sensor came with a 3/8 metal canister type fuel filter to put in front of the unit. I don't want that to be the first filter in my system as I feel it doesn't have the capacity off a larger spin on and has the potential to clog quickly. My question is would it be detrimental or cause excessive restriction in fuel flow if i were to add another spin on type fuel filter in front of the sensor and then have the engine mounted fuel filter behind it? If it is feasible, what brand filter would you recommend? TIA
