1998 Suzuki DT100<br />Pump the primer - and get it full. Engine starts great and will idle nicely - no problem with 2K RPM. Bulb starts getting soft. Replaced the fuel filter (big like oil filter). Removed cleanable filter from engine - no dirt visible.<br />When put into gear - starvation and stall.<br /><br />Replaced primer bulb - will test this weekend to see if it stays hard.<br /><br />Anyone have other suggestions?<br /><br />Does the DT100 have a fuel pump?<br />Do they go bad?<br />Can they be tested?
