Fwd-b1 oil change
boatfriendly
Hello, new to the forum, I’m trying to find information on a forward facing dual prop outdrive, I’d like to change the oil and check out the prop shaft, I can’t find much information on it though. Is it the same as the dual prop in the rear? Not as far as total disassembly but just concerning the oil change? Thanks in advance boat people
muc
"Retired" Association of Marine Technicians...
oil change is pretty much the same, except the drain plug is below the props near the front of the drive.
refer to your owners manual or use this link to download a free copy
props are held on with the system that the big boats use. pro tip ---- clean the allen heads out with a o-ring pick so the driver goes all the way in.
checking the prop shaft is covered in the drive workshop manual.
