gamefisher
- Jun 8, 2003
- 2
Does anyone know if it is normal when pumping the fule tank bulb for the primer on the motor to leak fuel?<br /><br />The carb has been rebuilt and a new diafram has been installed. It ran good for about an hour after that and then stopped! I found the plugs were fowled cleaned them and it started but ran very bad and would not idle. I discovered fuel in the engine compartment and found that it was leaking from the primer. Any body have a Manual out there or some good advice?
