Walker2
- Sep 3, 2017
- 62
Spent a lot of time investigating. Is there any chance of a bad coil even if ohms tests are good? I've got new points and new condensers. Bought one new coil as it did not test well. The new one works fine, the old one has no spark. Almost Identical ohms tests on both new and old coil. 7.5 K ohms From plug wire to top red wire and then to bottom red wire and then to ground. All disconnected of course for testing. Swapped points, Swapped condensers. Disconnected kill switch on both sides. All with same result: new side works, old side does not. Thanks in advance
