Re: Help! need info on mercury motor
Serial # will tell the exact year, but that looks like a 1975 or 1976 Merc 1150. I have the 1500 motor with the same style of cowling - mine is a 1975.
That is a 2 stroke, 6 cylinder motor.
50:1 gas
il mix.
Very good motor.
Sounds like you are ramping up your knowledge on your motor. Read up on your water pump impeller, what it does, how to tell it is working, etc. Water pump keeps your engine cooled with lake water. Overheated engines get damaged and the repair cost for these old motors will most likely exceed the value....
