Blake0912
- Oct 31, 2010
- 313
Re: Help please 90hp johnson two stroke issues.
That does not look like gear oil , more like a spent gas/oil mix. My 225 and 9.9 will do that exact same thing if I run the motor on the muffs because it will not get warm enough to burn off the excess oil. It will also do it after a De Carb , are you running some type of sea foam or fuel additive in this tank of gas? Could be burning off some crap out of your powerhead because of the cleaner in the gas.
Also ive found if i pre mix my gas too rich it will do the same thing.
Also what do you mean by your motor was " spitting smoke "
