Pink Shibi
- Mar 7, 2013
- 18
i have a 91 johnson 90hp two stroke that has been running fine until i caught a nice mahi mahi. then it seems as if i have offended some hawaiian deity. when i revved the boat back up after the fish it went fine till about 5-6 knots then it bogs down like it has no fuel or air. lower the rpms runs fine. if i pump the gas ball as i am running it will run fine. i looked at the fuel water seperator afterwards and it was full of water and dirt. i changed the fuel water seperator and ran it at idle 5 mins. turned it off and drained some of the fuel from it and a tiny amount of water. then i ran it around the bay for a bit pumping the ball to keep on plane. stopped checked it again just a little water and by little i mean maybe a drop or two. brought it home flushed it out and looked at the engine. noticed my service valve was cracked. so i replaced it. took it out on the water same problem. brought it back and was flushing it out. noticed that if i choked it it ran much better. so i was playing with that and the motor died. now it has issues idling at all. i am guessing that i need to drain the fuel tank and start over there and rebuild carbs, but before i do that i though i would see if anyone else has any ideas.
thank you for your help.
pink shibi
pink shibi
