how can I raise engine with trim motor inop
pedro
I need to get the boat on my trailer and home, but the motor will not move to the up position. Trim motor is frozen will not move up nor down. Thanks in advance.
JB
Re: how can I raise engine with trim motor inop
Sounds like an Outboard Question, Pedro.<br /><br />If you can get the boat on the trailer you can usually manually lift the engine and put a brace of some sort under it to hold it up while you tow it home.<br /><br />Tell us what engine you have.<br /><br />Moving to Outboard Forum.<br /><br />Good luck. :)
tgodiver
There should be a relief screw to release the pressure of the hydraulic pressure, Turn it three turns counter-clockwise to free the hydraulic pressure, and clockwise to maintain the pressure once you achieve the position you want.
pedro
This engine is weird. It's a force 120 but it is inboard. I have a 1991 maxum 2100SR. All I know is it is a "L" drive. This is my first boat so please bear with me. I purchased it about a month ago. I'll try the pressure relief. Once i get the engine up I'll tie it with rope to hold in place also. Thanks for the fast response.
roscoe
Pedro, according to my Clymers repair manual, there is no manual release valve on your tilt and trim unit.<br /><br />You may actually have to remove some hydrolic lines to release the pressure. Be careful, wear safety goggles.<br /><br />After you get it raised, place a 2x4 between the motor and the boat. Tie the board in place and then tie the motor down to maintain pressure on it so it doesn't bounce.
sparkroost
You could always remove the bolt for the lift cylinder. Carry a piece of wood with you to put inbetween the leg and the transom bracket.
pedro
Where can I get one of those Clymer repair manuals?
pedro
also, is there some type of bleed screw?
Hooty
You can get a Clymers shop manual right here on iboats. Look in the lower lefthand corner of this page and click on "Repair Manuals".<br /><br />c/6<br /><br />Hooty
Trent
Sorry Pedro.....L-Drive :( <br /><br />If you could sell it I would. Dont mean to sound bad but it is! Its on a Bayliner aint it?
pedro
Thanks for the reply. I got it home today. I romoved one of the hydraulic lines and tilted it up.
