how much does a mercruiser or OMC 3.0 engine and outdrive weigh?
Status
Not open for further replies.
Don S
Re: how much does a mercruiser or OMC 3.0 engine and outdrive weigh?
650 to 700 lbs. That's engine, drive, and transom shield.
180shabah
3.0 Alpha package = 695lbs.
Need the weight to figure floatation for a boat I'm re-doing....
Ayuh,... Don't forget to include the floation value of the Air in the cylinders...
wire2
And also the flotation value of hundreds of small air bubbles in typical cast aluminum.
Status
