how to start 470 on garage floor. wiring
littlelund
I have the engine sitting on the floor and I want to start it up and let it run a little bit. Just wondering if someone could go through the exact procedure to wire this up to run.. I have the starter hot and ground hooked to the battery. Just not sure what pins on the harness needs to be jumped to get the ignition up and running. can someone walk me through this. I've searched around and can't seem to find what pins do what.
Bt Doctur
Re: how to start 470 on garage floor. wiring
just run a jumper to the coil for a quick run, if longer run needed use a ballast resistor from a auto store inline with the jumper wire or wire jumper to the hot side of the electric choke.
pin 5 is ignition circuit
Agree ^^^
forget the harness and pins. Jumper wire w/ alligator clips from (+) batt to (+) coil or choke as he mentioned.
remove jumper to shut engine off.
littlelund
awesome.. thanks for the info and pics. Got it fired up with jumper to the coil.
