Hull Cleaner
zippy83
Fellow Boaters,
I have head this question before and I was told to use Oxalic Acid also knows as Wood Bleach on my 16ft aluminum boat, however I am not able to find that acid anywhere. I looked at Lowes, Home Depot, Ace, Menards, no one knows what I am talking about.. I searched google but all I come up with is a few youtube videos and some posts from this website.
Any idea on this one?
Thanks
Zipp
zippy83
Re: Hull Cleaner
Thanks. I totally forgot about amazon. Once again this is safe to use on aluminum hulls? I have seen multiple videos on how to ise it on fiberglass hulls.
bruceb58
Re: Hull Cleaner
I have no idea if its safe to use on aluminum. My guess would be no.
zippy83
Re: Hull Cleaner
so I did some search and Oxalic acid is not safe or recomended to use on any aluminum... however some guys used toilet bowl cleaner "The Works" that contains some of oxalic acid and they said it works and wont eat your paint... im not sure how true that is though...
efhughes3
Re: Hull Cleaner
It's been a while since I've bought it, due to not needing it, but this used to be readily available at marine stores. Maybe it's an EPA thing now, and not readily available, as boat use would end up with it being rinsed off into the water?
Ed
moosehead
Re: Hull Cleaner
Repeat from other similar threads below. Acids tend to be tough on paint over aluminum and can also score the metal. YMMV.
MSDS review of some mildly acidic cleaners popular for hulls showed the following in ascending order of acidic strength:
Starbrite: 5-10% Oxalic Acid
Bar Keeper's Friend: 5-10% Oxalic Acid
Sno Bowl: 10-20% Hydrochloric Acid
Mary Kate On Off Hull Cleaner: 20-25% Hydrochloric + 5-10% Phosphoric, 1-5% Oxalic
zippy83
Re: Hull Cleaner
So here is what I got from a local marine shop...
BEFORE.....
AFTER.....
All I had to do is add 1/4 of water to the mix, make sure the outside temperature is between 50F - 80F and make sure not to use this product in direct sunlight. I applied it to a dry surface and let it sit for 5min and rinse it with water. That is all!!!
