humidity readings
rick911
Need some help from you guys, just had a survey done on my boat.humidity readings on the hull shiite 20 to 50%. In the transom they indicate 70% next to the stern and 80 near the drain plug.
Now my question is, should I be worried about this?
Bob_VT
Re: humidity readings
Welcome to iboats
Was this survey done by a professional? Is it on your current hull? There should have been a summary report provided with some explanations.
The readings you have posted would absolutely concern me and it sounds as if this could be a large scale restoration.
Since a survey covers all of the boat I would want to know hull material, age, type of boat, motor, drive system.
We have had member's here on iboats spend $500 on surveys however, it has saved them thousands in future repairs or given them pice of mind on a purchase.
What kind of boat.
More information is needed.
