Slice of Life
- Apr 2, 2013
- 78
I'm ready to make a compression test on my 1992 Mercruiser 5.7 350 with Thunderbolt IV ignition system, and after reading a lot of posts here regarding making a compression test, I'm still a bit confused on grounding the ignition coil. I've never done a compression test and am new to this. Some say simply remove the coil wire to the distributor cap. Some say remove the safety lanyard wires from the switch. Some say using a jumper wire to all the plug wires and ground them to the block. The simplest seems to be using a grounding jumper wire on the ignition coil to each of the two wires connecting each other. This is what I've done and do not want to damage the ignition system by doing this incorrectly. All plugs are removed, wires moved away from the engine, and I have my test kit ready. I'm assuming having the throttle all the way forward sufficiently sets the carb correctly. Thanks.
