76SeaRay
- Aug 24, 2017
- 1,071
First issue is a confusing anomaly with the distributor. This is a new Mercruiser OEM distributor. From pictures I have seen on other engines, the area where the ICM mounts on the distributor is pointed towards the Port side and the wire terminals and optical "points" sensor are pointed to the Starboard side. I am used to GM engines with cylinder one oriented to the front. However when I mount the distributor cap that has nicely marked cylinder numbers, they show number 1 being to the back of the engine just opposite normal GM orientation. Pictures below. Am I missing something here? By the way, my TB V ICM will mount on the Port Exhaust Manifold and will not be attached to the distributor.
