scout-j-m
- Jul 31, 2009
- 643
So I finally bought a new Faria tach to replace the old one that hasn't worked the entire time I have owned the boat. Getting a new tach was a pretty big deal as my 1994 70HP Force has never run right and I am committing myself to fixing it this spring/summer.
Anyways, I set the tach to the 12 pole setting and installed it no problem. My fuel system was disconnected so the motor wasn't going to start but turning the motor over the dial didn't budge. I checked the voltage between the power terminal and negative terminal of the tach and got 11.8V so I know it has power and a good ground. The connection of the sender wire to the tach is solid as well. Before getting into all of the rectifier/regulator tests, can I check the voltage directly at the sender wire at the tach and directly where it comes out of the rectifier? If I read previous posts correctly it should see about 18V AC and fluctuate with RPM increase. If that doesn't work can I jump the gray sending wire coming from the wiring harness butt connector directly after the rectifier to one of the yellow stator wires' butt connectors and expect to see the tach work?
I'll go through all of the necessary rectifier tests when I have the time but currently working on some other issues to get this thing running right is a higher priority. I would just like to get a tach signal by jumping the rectifier so I can perform other checks, set idle, etc.
