Re: johnson lower unit question
Is that manual shift or Electramatic shift?
The manual shift lower unit was used on all the V-4's except the 90 & 100hp, from 1960 up through 1968. The 1960 was different, but will fit if you use the whole unit. But I would avoid doing that, since there was a reason they changed it.
The electric shft lower unit was the same on all V-4's except the 100hp, up through 1968.
