Hello, I have a 2013 Mercruiser 4.3L MPI 220HP engine. The manual stipulated the engine to run for a few minutes using a mixture of fuel, 2-cycle oil and fuel stabilizer to properly winterize the engine aside from changing the engine oil, flooding with anti-freeze, etc. Can anybody answer the following questions?
1) What will the damages to the engine be if only a fuel stabilizer is added to the fuel and without the 2-cycle oil?
2) Where is the fuel pump located? Is it in the fuel tank or on the engine?
Thanks for any info you can provide.
