Mercarb 2bbl flooding after engine stops
toneybrown
So, last summer I had this same issue. Stop the engine and fuel would drip down, then the boat didn't want to restart until all the fuel evaporated or I opened up the throttle to let it air out. Last summer I installed a new needle, seat and float. Adjusted everything and the flooding problem stopped.
Today I pulled the tarp off the boat, reinstalled the points and changed oil. Had a hard time getting the engine started, but some starter fluid seemed to work. I killed the engine and fuel was dripping into the carb at a much higher rate then when I had the issue last year. A very fast steady drip.
I pulled the carb off, checked the needle and seat. Readjusted the float to 14mm and 27mm drop. I am currently using the spring. As that is what was in it when I first tore it apart last year.
So, is there some other adjustment I need to make? Is the float adjustment I found incorrect? I measured from the bottom dot on the float to the rim of the carb.
Any help is appreciated.
Rick Stephens
Might measure fuel pump pressure. But likely you got crap in your carb. A little goes a long ways in needle valve seats. Could also be a float with a little leak, and it's getting heavy. Or simply a bad float height adjustment.
toneybrown
I'll pull it all apart and clean as best I can. I'll double check my float adjustment. I don't have the necessary equipment for a pressure test. Not sure how exactly to do it.
toneybrown
One thing I left out of my original post. I actually pulled the carb off twice. After the first time I took it off I just adjusted the float a little down. When I put the carb back on I was not getting any fuel to the jets, and the boat wouldn't run at all. When I unbuttoned the top of the carb before removing the whole thing, there was something like a pressure release or vacuum release from the bowl side. I'm assuming this would be normal if the carb was sucking air out of the bowl instead of fuel?
Rick Stephens
The Mercruiser manual for your motor will give you highly detailed instructions on how to rebuild that carburetor. It needs a kit and done exactly properly. Sounds like you've been guessing, that won't cut it if you want the motor to run right.
toneybrown
I took the carb apart again and found some debris in the seat. I think it may have fallen in from all the crap blowing around the air right now. Should have done a better job of making sure everything was cleaned out before putting it together.
Now I just need to figure out why my idling is wonky. If I get it to idle around 650rpm it will eventually bog down and die. Almost like it ran out of gas. I have to pump the throttle before it will restart. It will then idle for several minutes before bogging down and dying again. If I increase the idle to closer to 800 rpm it seems to idle as long as I want, but the rpms jump up and down 150-200 rpm. Not sure what is causing the fluctuation. I may change the points to a new pair I have just to make sure they aren't causing a problem.
the fluctuation is from crap in your fuel and carb.
pull the carb apart, clean it thoroughly, then assemble with a new gasket kit.
most gunk in a carb is pumped in to the tank
