Re: Mercruiser 165 Engine Problems
hi mike, you've come to the right place for help, that's for sure. these fellas here have helped me a lot...
could be carb, and does sound likely as others are saying. and for sure check the fuel filter. make that just R&R the filter, it ain't hard to get to and is cheap. check the screen at the inlet of the carb too. it is cleanable and can collect debris too.
prior to carb adjustments though, have ya done a minor tune up on to it? ya know, points, condenser, cap, rotor, plugs, set dwell 1st then timing. prior to assuming the carb. do the electrical side 1st unless your sure your hip there. check compression too. if not only for a base reading for checking against later on. but ya do gotta have something to work with...
also, speculation. but dies when shifting on your version of mercruiser can be a sign of a bad shift cable.
more.
go here.
http://forums.iboats.com/showthread.php?t=342393
there is much info here. probably service manual #2 (which has trouble shooting guides in it too) for your 77 (confirm proper manual by s/n if possible) which is a must have item for working on your rig. it's all good there. read them all even.
have ya gone here yet..
http://forums.iboats.com/forumdisplay.php?s=&daysprune=-1&f=224
some interesting info for our boats, browse and enjoy.
so what color ya got? pics? mines lime green...
a few pics scattered around over on the aristocraft forum of it...
edit, just looked at your old posts. no one answered about your cover. i missed the thread somehow. did ya get it figured out. i found one that fits and can likely find the part number for ya if ya want me to look back through my records..
