DeclansDaddy
- Oct 4, 2014
- 33
Hi guys I have a 95 200hp Ocean Runner that has low compression. 80-90 psi on all 6 cylinder. I know it's time for a rebuild but will this motor perform ok with this low of compression. I've read anything under 100 is bad but I'm just wondering if I can get through the fall and rebuild this winter with no problems(due to compression). The motor needs a few more things and I was trying to determine if I should get those parts and go or if I should just hold off and do it all at once.
