king salami
- Apr 25, 2013
- 16
Re: More hp then rated for
you already have your answer: "in most states it is illegal therefore unless you know for sure that it is legal you can assume its not". in CA if you are towing a boat on trailer that is over weight rating for your vehicle you are liable to get a ticket(not that people get stopped for such things) and should you get in an accident even if someone blatenly crashes into you, you would certainly be held responsible as if you were dui. im sure the law is along similar lines when it comes to overloading a boat whether its people weight or hp rating. that being said, there are a number of ways to go about it that may be outside the confines of the law that you might not get busted for. you could grind or alter the capacity plate, change the crowling(sometimes different hp powers of the same make and model year outboards are the same size because little differences like carburation give the motor higher hp such as a common 15 to 9.9 job), change the decals on the crowling(order replacement decals from an 18hp of the same make) or fix your 15 hp.(not to get into that to much but try starting fluid in the breather and make sure to use fresh gas. dump the old gas in a 5gal bucket pour a little fresh gas in and swish it around and dump that to remove any dirt in the tank.)
New to iboats this is my first post, hope you find it helpful. also any notes as if it was to long or if thats ok if the info is "good" thanx.
