Hello everyone. I could use some great guidance here in replacing these fog lights on a 1993 Godfrey Hurricane deck boat. Lights are dead and rusted out.
Everything I will describe is as if you are looking at the boat straight on from the front.
There are two fog lights as you can imagine on both sides. They have stainless steel bases which are bolted on through the top of the boat. The bolts have a round smooth head and are secured with nuts from inside the hull.
The light on the right was real easy to remove since there is an access port up front and on the right side of the boat. I was able to use a 15mm wrench and vice grips to remove it. Just reach in through the porthole and go at it.
My problem is the light on the left. There is absolutely no way that I can reach this light from the porthole. I'm at a loss as to how to go about removing this one.
If anyone is familiar with this and can lend any type of adivce on how to remove and then reinstall the new light, I would so greatly appreciate it.
If you have any other questions, just let me know.
Thanks kindly for your assitance.
J.
J.
