Bought a new boat Thursday a 98 Four Winns with Volvo penta 4.3 GL and Corbra sx combination. Brought it home cleaned the boat up and fired it up running on muffs. Everything sounded good in the yard. Went to the lake on Saturday backed the trailer in the water and fired up the boat, it started right up and sounded good. We backed it off the trailer and headed out to open water at no wake speed. We hit open water started cruising around the lake. After about 10 min I smelled something burning, shut off the motor and opened the engine compartment. Smoke was pouring out, I looked to see what was causing the smoke and it looked like something had got melted all over the drivers side exhaust pipe after the riser but before the boot that ties it into the 'Y'. The riser on the driver side was super hot but the passenger side was hot but not to hot to touch for a few seconds. We got towed back to the dock by another boat I heard splashing in the bilge area and could see water coming in for the lower rubber boot on the drivers side exhaust pipe when we hit waves. I kicked the bilge pump on and it kept the water to a low level till we got it on the trailer. The Temp gauge on the dash was at 160 degrees before I smelled the smoke, I was watching it pretty close since it was my first time on the water with the boat and wanted to know where it would normally run. Couple of questions.....
1) How bad did I screw up my new boat?
2) What temp should it start circulating water to the engine and exhaust or should it all the time?
3) What should I check first?
