Re: Nissan 25 HP 1992
A few years ago I asked a tech at maxrules.com about the difference between a '99 25 and 30HP as they are basically the same engines. This is his reply:<br /><br />"Aloha - -<br /><br />My Nissan service manual shows both the 25C2 and the 30A3 and 30A4 at 25 <br />degrees BTDC total advance. I suspect the only difference is a restrictor <br />plate between the carburetor and manifold. Also, check the cam that opens <br />the carburetor, ensure that it opens the butterfly all the way!"<br /><br />A swedish dealer later confirmed the only difference is the restrictor plate (ie carb gasket). <br /><br />Have you already done that?
