OIL INJECTION DISABLE ON SUZUKI DT65
baseline1
CAN SOMEONE PLEASE HELP ME IN DISABLING THE OIL INJECTION ON MY 1993 DT65? I NEED TO KNOW WHAT WIRES TO DISCONNECT FROM THE ALARMS. PLEASE HELP.
Spidybot
Re: OIL INJECTION DISABLE ON SUZUKI DT65
Ho! Please hit the Caps Lock key...<br /><br />Capitals are considered SHOUTING!<br /><br />Why do you want to disable the oil system?<br />Anyhow: If you do not trust it and want to make sure you're lubed, fill both fuel tank and oil tank with your preferred premix! If the oil system works - fine! If it doesn't - fine too!
jim dozier
The Suzuki oil injection systems are very good. They have the added advantage of injecting oil into to intake manifold upstream of the carbs, so clogged jets do not reduce lubrication as happens with premix. Get a manual. It is not hard to quantitatively test the output of the oil injection system. If its working OK, leave it alone. If its not, it probably only needs a new filter, check valve, or tubing.
