Older style evindure throttle control
boater10
Too All:<br />Have another topic to discuss. On my boat with a 1970 40hp Johnson is a evinrude throttle controller. It has 3 buttons. 1 for forward, 1 for neutral, and 1 for reverse. Are you actually suppose to push these buttons down before moving between each position. Example: If I'm in neutral, do I push the reverse button to move to reverse or Do these buttons move up and down when you move the control arm back and forth. Maybe a stupid question but I have been pushing the buttons before performing and action with the arm. <br />Appreciate your time<br />Steve<br />Dartmouth, Nova Scotia
lark2004
Re: Older style evindure throttle control
You have to press the buttons. Do this while you're idling, changing gear with to much throttle will break the drive spring in the gearcase.
boater10
Lark:<br />Thanks,and will do. Will let this forum know how it goes.<br />Thanks again<br />Steve
