Abomb27
- Jan 6, 2013
- 141
Re: Omc 115 Turbojet stripped down and starting the rebuild
First time doing them, first they would stick to my finger, then I was trying to put the wrist pin through the washer then through the rod bearings, and I kept knocking them loose. Then I figured out to go through the washer and rod bearing in one piece, and slide the last washer in. If I had a second motor to build, probably could do it in half the time, with all the things you pick up from the first one. Always learning.
