OMC Cobra 3.0L Starter Wiring
Status
Not open for further replies.
metapath
My father has a Bayliner 20 ft circa 1987 with OMC Cobra 3.0L engine. He pulled the starter and had it repaired. When he re-installed it, he couldn't find his homemade wiring diagram.
It doesn't look correctly wired to me but I have no idea what should go where. Needless to say, it's not working.
Can anyone help? A picture is worth a thousand words, but I'll settle for a hundred words if they will help me wire this thing up.
Thanks much!:%
Re: OMC Cobra 3.0L Starter Wiring
It would be even Easier if You explain What you See,+ We'll help you figure it Out.......
Don S
A. Should have 3 red cables. One of them is the main battery cable.
B. Should be Yellow/red stripe wire
D. Should be Purple/black stripe wire.
metapath
Well, he's got all the "big" wires, that is the red battery cable, and two other black large wires connected to the large post on the solenoid. There's two smaller wires on two smaller posts...one goes up to the coil and the other elsewhere.
I'm afraid that's all I can describe. I'm on my way back to Seattle (my father and the boat lives in southern Colorado). I could ask him to take a pic and email it to me...
Does the above help at all??
metapath
Wow, thanks Don! This looks like the ticket. I'll send to my dad and brother and see what they can do with it. This board is great!!
-Jon
18nsmith
Hey, I know this post is nearing 20 years old, but we're having the same issue on the same boat. The images on this thread won't load for me, maybe because of the age of the thread or something. Did you ever solve the problem? Would you be willing to help me figure the wiring for my own starter out?
-Jon
Bt Doctur
B battery cable, main system power ,alt charge wire.
S yellow/red from slave to operate the starters solenoid
Status
