WEEDWACKER
- Apr 21, 2002
- 6
I have a skeeter bass boat with a 150 h/p marine on th back. I also have a jack plate on it .Just bought the boat and got in runing . But i idle at 10-12 psi water pressure. when accelerating foward the water pressue will drop slightly when you let off it will raise , when the boat is on the pad it backs off to 6 psi and according to were it is trimmed will not run over 10 psi when turning it will run 6 psi .. the motor is 3 " above the bottom of the boat measuring by the cavitation plate. the boat transom is 22-23" from bolt hole to bottom.. the motor is 18-19 from top bolt hole to cavitaion plate .. i cant drop the motor any motor because the controls hit the transom.. whats the cure?.
