1998 mercuriser 4.3 (GM remanufactured) with alpha 1 gen+ out drive, on a 1998 regal valanti 176se
The out drive itsself has a bit play from side to side if I push (sure during trailering). I searched the forum, and then tightened the top two screws on the top of gimbal ring but these two screws just keep turning(not loosely) and just couldn't reach to the 55lb torq. Is there a back nuts also loosing behind from transom side?? I looked inside there are two screw nuts and those are not rotating while I tighten the outside two screws. Should I just keep tighten, I dont want to risk the ring? Do you guys feel this 1 inch play can damage the ring during the transportation? The play is only side by side, not up and down.
Thanks!
Thanks!
