zippy83
- Jan 1, 2013
- 499
Hello all,
So this year is starting out with a bunch of problems. I own a 1973 50HP Mercury thunderbolt. Today I took it out for a spin and it was working great. when I got back to the dock I shut it off to pull the trailer in. When I got back to the boat I couldn't turn it on. When I try to turn it on I could hear a lot of clicking noise coming from the outboard. I pulled it in with my trolling motor and went home plugged in the battery to charge and waited 10 hours. Then I hooked up ear muffs and wanted to give it a go and nothing. Just the clicking noise. The battery wasn't fully charged only at 75% but usually it started with it being 75% full.
So I took the battery out of my car (only 6 months old) hooked it up and same result. the flywheel wouldn't even move. Just a tiny bit. So the teeth on the starter (on the very top) were aligned with the teeth of the flywheel, it was like that when I pulled the cover down so I took a screw driver and gently pushed the starter top part down to see if the starter would turn at all, and it did, however it is not kicking up when the key is turned. to my knowledge it should kick up and align with the flywheel right?
You can see the picture of the top part of the starter. Sorry I dont know what the name of that part is. I put the battery to fully charge. It is about 2 years old got it march of 2012... but I am now wondering why the car battery wasnt able to spin it.
Any suggestions?
Thanks
Zipp
Any suggestions?
Thanks
Zipp
