Prop on an older Sundancer
Begester
The other day I destroyed my already "not so good" prop trying to tow a
stranded boat into shore, and its time for a new one. I've got a 1989 SeaRay 24 foot Sundancer that currently has a 14.5x17 inch prop. I've got a 5.7L engine on an Alpha I outdrive.
The old prop was great all around, I love it for cruising and was able to even get a wakeboarder up when we tried that a couple weeks ago. I had a couple of questions though...what (if any) are the advantages to upgrading to a 4-blade prop? I don't have a need to go 45 mph on this boat, but sometimes I get the feel that I'm not getting enough bite when I'm at cruising speed of about 30-32mph and 3500rpm. My thoughts are that if I can get the same bite of water with less rpms, that will equal better fuel economy. Is this logic accurate? I also understand that if I go up to a 14.5x19, I can get about the same cruising speeds with a little less rpms, which I see as a fuel savings. Am I wrong there?
Lastly, and hopefully this isnt too stupid of a question, but I go through about a 1.5 mile channel (no wake zone) between my marina and the open lake. It seems as though I have to barely crawl in order to not put out a wake, would a different prop pitch help that? Similar boats my size seem to be able to move a good bit faster (relatively speaking) without putting out a wake, would a different prop do anything here?
I have an aluminum prop on there now and would like to stay with aluminum.
Any thoughts are greatly appreciated!
Happy boating.
Re: Prop on an older Sundancer
Ayuh,...
I'd go with the Same prop you have, only New....
Lowering the rpms with a bigger prop will overload the motor,...
That equates to a possible small increase fuel mileage,..
At the cost of burning up your motor....
And,...
Changing props will Not change the amount of water your boat displaces,...
Aka. Same Wake....
Begester
Thanks for the help! I'll let you know how it goes
Randybeall
If you want to get serious and reprop for best efficency you need a bit more information. If you wish to just replace the prop, stick with the pitch you have. A 4 blade prop will improve the inital acceleration, hole shot, if it is a ventilated type. Trim tabs might cure your wake problem. They mount to the transom and increase lift at the rear of the boat making it pass through the water easier. That will change where you trim the drive but might solve your low cruise problem.
