Question about my engine wiring
mrstevewayne
I have a Johnson 1988 GT 150 hpVRO V6. I am attaching a picture below, The brown wire in the picture only has a couple strands of copper holding it attached to the plug. Can I cut the plug out and rewire with heat shrink connections on all three wires, or try to pull the pins out and re-solder them? I do not know a part number I would use ti order another on, being how this is a 1988, or if one is available. Any advice? see pic attached
Chris1956
New engine harnesses are likely available as well. You might price one out. Sierra or another aftermarket manufacturer likely makes them as does the OEM.
