ksauerwald
- May 7, 2013
- 25
So I looked at the diagram.. watched a couple of videos and from what I can tell I should be able to either detach the gearbox from the bottom the extender or the extender. Then pull a part a bit and find the shift rod connector... but... I dont see it.. I just see the rod.. so do I need to detach it somewhere else ? somewhere lower or higher ? I just dont see it in either section.. just the rod
so more back story.. maybe you can point me where to look and maybe I dont need to take off the gear box.
once and a while when jumping waves in my little cougar cub with the 28 on there it would spin real free.. almost like we were getting air.. so I figured that what is was.. but last year that noise can back when doing nothing.. so I assume one of the gears is shot.. so do I just need to take apart the bottom gearcase where the prop is ? or take it all apart ?
and one more question... why would someone put a gearbox extension on a motor ? does it help pop out of water ? why is it a long shaft ? and should I take it out ?
