HI All
I am about to remove a CAM shaft from my Mercruiser 4.3 v6 1998, I have already removed the heads and the drive chain and sprockets before I step into the unknown could anyone please advise me on this task ?
I also I have a second question it is possible to set the valve clearances on this design as I have cam lifters and push rods there doesn't seem to be a way to set any type of clearance or is the clearance just set on a torque setting ? or is it to do with the tension on the spring inside the lifter?? any help on this would be much appreciated
