How are these things to re-seal if you remove them completely?<br /><br />After closer inspection, the bolts that hold the gimble are rusted BADLY. There is also 1 rusted bolt whre the exhaust elbow used to go (now there is a block-off plate)the nut is gone, and I cannot get it loose. The other bolts are rusty too, but not as bad.<br /><br />My thought are to just go for broke and remove the gimble housing, as I need to replace all the belows and bearings anyway. <br /><br />Anyone know where to get a bolt kit for the gimbal housing?<br /><br />Thanks,<br /><br />H.
