removing the outdrive...
krisnowicki
So I took the engine out and am about to put the new one in... I have disconnected al the electric and cannot use the power trim to put the OD back down what can I harm if iremove it while it is up? Or will it come out the same just be a bit harder
Bt Doctur
Re: removing the outdrive...
type of drive?
type of motor?
Most drives using a shaft need to have the drive removed first before removing a motor. then the engine is installed and aligned.you can`t just slide the engine back in.
krisnowicki
pre alpha mercruiser... I need to know if i remove the outdrive while the rim is up will hurt anything
Bt Doctur
unbolt the rams at the rear anchor point and lower the drive, shift into fwd gear, remove the 6 nuts and pull off.
Don S
Every outdrive Merc used before 1985 is a pre-alpha drive. Get used to putting actual year or model numbers on your posts. it will help in getting the proper answers.
Assuming this is a One drive or newer, put the shifter in forward, remove the trim/tilt ram pin from the back of the outdrive and let the drive down. Then remove the 6 bolts.
Don't forget to check and adjust your engine alignment when you get the engine back in.
thunderroad
Am I missing something, or won't you have to unhook the trim cylinders to get the drive off anyway?
oops...looks like you got your answer while I was typing
