Removing Yamaha Trim Motor
goradal
I have a 1995 Yamaha P150 ProV, the trim motor has failed. How does one go about removing the motor it has 3 bolts of which 1 you can not see or get to without some disassembly. <br /><br />Thanks
Ray Neudecker
Re: Removing Yamaha Trim Motor
You will have to remove the clamp bracket keeping you from getting to the bolt. This involves removing the engine from the boat or at least supporting it while the clamp bracket is removed. Can be a major job if a saltwater use engine. Good Luck.
